Re: New to me (Gooseberry) water heater.......
Info from my dad a few minutes ago...
Parts purchased from
Rixen Enterprises
Sandy Oregon
Rixens.com
1-800-925-6260
Owner is Jim Rixen
Rixens’ specializes in RV heating utilizing Espar Hydronic units, but also sells individual components.
I have a Winnebago View RV on a 2006 Sprinter chassis. It is seriously modified with the ultimate goal of completely eliminating propane. I have 400Ah of LiFePO4 batteries, 400w solar, 240 amp alternator with a Sterling Alternator to Battery charge controller and a Magnum 2000w sine wave inverter/100A charger, so power is not a problem.
My first project was to eliminate the stock water heater by using a few of Rixen’s components to heat the water using the 1500w, 120vac heating element, and later plumb in the hot engine/ Espar coolant .
Main component is a tank that Rixen calls the Comfort Hot. It is a 2 gallon aluminum tank with a standard 7# radiator cap on the top. On the end is a gray box that houses a 1500w 120vac heating element, thermal protection and wiring. On the bottom are 3 1/2” threaded pipe openings, (coolant input, output and drain).
Other 2 components are a small heat exchanger and a small 12vdc circulation pump that circulates the hot coolant from the Comfort Hot through one side of the heat exchanger.
On the output side of the heat exchanger I simply plumbed my cold water into one side and and used a Honeywell AM1 thermostatic valve on the output side to set water temperature to 105 degrees, this removes the need to fiddle with the hot/cold to get uniform water temperature for a shower!.
This closed system will heat the coolant to 170 degrees in the Comfort Hot tank in about 15 minutes. The Comfort Hot heating element will cycle on/off to keep the tank temperature between 150 and 170. With the small circulation pump running I can get approximately 3 gallons of continuous hot water at 105 degrees for a shower before the coolant temperature drops. Of course, using hot water at the sink in the usual intermittent way while washing dishes, etc, the system will keep up with your use.
When fully plumbed into the Espar or just engine hot water lines the hot water supply will be virtually continuous as long as you have engine heat. When using engine heat you will have hot water as fast as you engine heats up, probably faster than the 1500w heating element, which is actually meant to be a backup system or used when shore power is available.
These 3 components, Comfort Hot, heat exchanger, circulation pump and Temperature control valve cost a bit over $1000 total, and I also needed a few fittings, 3/4” heater hose and clamps.
Next step - Plumb into the engine coolant lines. My Sprinter already has a stock Espar diesel engine preheating unit. It pre-heats the coolant by firing up a small diesel furnace in the engine compartment and circulating the hot coolant through the engine block. As many others have done, I plan on tapping into that hot coolant hose and have it heat my hot water with a heat exchanger and cabin with a small radiator and fan. Modification to the Espar unit and engine plumbing are required to use it as a stand alone heat system independent of the engine . These components are all available on the Rixen website.
John Haywood
