Old 09-01-2021, 12:59 PM   #1
Question/help about welding nuts to steel plate
Hi all,
I’m working on a project that needs nuts secured to the bottom side of the steel plate that will not be accessible when the plate is in place. I’ve been trying to read on line but thought I would also reach out here to get some in out.
I’m looking to use a standard Miller welder to weld nuts into place on to a 0.1875” steel plate. I know weld nuts are an option but it seems that a special tool/equipment is needed. I’m wondering if a general low carbon steel plain finish hex nut can be welded to a steel plate? Any suggestions or input would be appreciated.
Wisco150 is offline   Reply With Quote
Old 09-01-2021, 03:53 PM   #2
Yes, just use a tap and re-thread when after welding. Just keep in mind that soft hardware shouldn’t be used for passenger restraints or seating.
Old 09-01-2021, 07:14 PM   #3
1der's Avatar
Cross nuts or other name Plus-Nuts might provide a solution depending on size of bolt/screw you plan to use. They are available to accommodate a couple of different depths.
Old 09-02-2021, 07:37 AM   #4
What's the challenge with weld nuts?
Drill a hole in the plate stick the weld nut through and weld....
https://www.mcmaster.com/weld-nuts/
Old 09-02-2021, 09:50 AM   #5
deserteagle56's Avatar
Originally Posted by Wisco150 View Post
Hi all,
I've done this multiple times, using an old Lincoln welder. Works well. Just make sure, as Carringb suggests, to run a tap (or even an old bolt) through the nut to make sure the threads are still clean.
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 09-02-2021, 09:54 AM   #6
Pntyrmvr's Avatar
And definitely use an unplated nut that is ground clean.
Old 09-02-2021, 09:49 PM   #7
larrie's Avatar
One solution is to drill the plate, put a bolt through the hole, tighten the nut down weld the nut and then remove the bolt. This works especially well when precision placement is needed.
Larrie
Old 09-03-2021, 12:20 PM   #8
Hi everyone,
Thank you all for your input. I didn’t really even think of the potential need to use a tap.
My concern about using actual weldnuts is the projections on weld nuts, from my understanding (only from reading on google, no actual experience) is that the projections are there to used with a projection welding tool rather than a standard welder.
I have some test pieces of metal with holes drilled and ordered a small quantity of bolts to see what method works best/most consistently before trying it on my final panels.
Old 11-17-2021, 11:39 PM   #9
You will need to use a unique tool because the material is stainless steel, and stainless steel requires unique materials if you are going to weld it because the standard electrodes used in arc welding may not work correctly. The electrodes generally used in stainless steel welding are ERTiN52 or ERTiN32, depending on the grade of stainless steel that you are trying to weld. You can find these electrodes at any welding supply store. There are many welding courses available for various types of welding. It will help you.
Jonathan Cole is offline   Reply With Quote
Old 11-18-2021, 10:19 AM   #10
I don't see where the OP mentioned stainless.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
