Old 06-18-2023, 02:09 PM   #1
Angry Advice on sealing back doors
My 2012 E350 lets in lots of dust from the trails. The weather stripping looks ok. Due to interior buildout I can no longer use the light through the crack method of looking from the inside out.
I would simply replace the weather strip but it looks perfect. Obviously it's letting air in from "somewhere" but how to tell where?
Anyone deal with this before and did you solve it? What worked for you?
Thanks,
Jack.
JackSlack is offline   Reply With Quote
Old 06-18-2023, 03:10 PM   #2
marret's Avatar
Arctictraveller has made some good posts about dust intrusion mitigation. You might try searching for “dust”.
Try this thread:
https://www.sportsmobileforum.com/fo...oors-1433.html
Chris
Old 06-18-2023, 05:18 PM   #3
My first SMB 2005 had multiple holes drilled thru flooring - under cabinets and sinks - and "nothing" going thru them ! I'd suggest crawling under the van at night - and shining a flashlight up into chassis flooring - and have someone else look inside the van as you move around - with several corks and liquid nails ready to stuff into any holes found. I found at least 5 such holes !
Old 06-18-2023, 06:33 PM   #4
That's an awesome suggestion. Thank you.
Old 06-18-2023, 07:41 PM   #5
deserteagle56's Avatar
Keep your windows all closed and your climate control fan on high...to pressurize your interior. Only way I've found to keep out the dust.
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 06-18-2023, 07:47 PM   #6
dhally's Avatar
+100!!
Even if you can't see the dust, driving with the window open sucks it in the back, badly. Definitely run the HVAC fan.
2009 E250 RB 5.4L "SilVan"
Old 06-18-2023, 08:29 PM   #7
I've been reading past threads. It is obvious I am not alone in this issue. Thanks for all the suggestions.
Old 06-19-2023, 08:28 AM   #8
There are drainage holes behind the door trim at the very bottom. Exposed to the „outside world“.
Depending on whether or not your vapor barrier foils is still on, that might be another source
Old 06-25-2023, 09:51 AM   #9
I used a roll of soft insulating tape used for house doors and ran it along the inside of all the door frames in the van where they shit and meet eachother. It drastically reduces the dust inside.
Tbro47 is offline   Reply With Quote
Old 06-25-2023, 12:31 PM   #10
You mean on the body or on the door? Pics? :-)
