Yep, Frame mount Sway Bar bushing. If you plan on replacing them, measure the diameter of the sway bar and the width of the bushing. You do want to replace them both, and buying the correct size bushings is important to ensuring optimum performance from your sway bar.
Inspect your stabilizer bar end-links as well, may want to including replacing these at the same time.
YouTube has plenty of helpful videos on how to replace them, and you can find all types of bushings on Amazon (some specific, some universal)
EDIT: If you are experiencing 'noise' coming from the sway bar, it could just be your end links. I believe MOOG makes 'Problem Solver' end links which are very popular.
