Old 07-25-2022, 12:21 PM   #1
jeff00seattle's Avatar
Question RB50 refrigerator replacement suggestions
Hello
I have 2001 SMB RB50, still with original Norcold refrigerator.
Seals are no longer tight and constantly running.
Seeking suggestions for replacement.
Thank you
Jeff in Seattle
2001 Ford E-250 RB50
jeff00seattle is offline   Reply With Quote
Old 07-25-2022, 01:00 PM   #2
BrianW's Avatar
Search "Truck Fridge" on this forum and you'll find a lot of info.
Old 07-30-2022, 04:09 PM   #3
Hello, recommendations for replacing Norcold DE-451 on this forum is a TruckFridge.
Any specific model of TruckFridge recommendation?
Jeff in Seattle
Old 07-30-2022, 04:50 PM   #4
Steve C's Avatar
Replaced mine last year with the Truck Fridge TF65 AC/DC. Only needed to modify the wood blocking underneath the fridge to get proper height in the cabinet and it was plug and play. Some on this forum have recommended just going with the DC stand alone, but I decided to stick with the duel power model.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is offline   Reply With Quote
Old 07-31-2022, 06:53 AM   #5
Have a 20 year old Nova Kool in my van that still works perfectly. if it ever dies, I'll get another one exact same make and model.
Old 07-31-2022, 06:59 AM   #6
I asked the manufacturer directly about this feature. They said the 110 volt option is there in case you want to use it somewhere that doesn't have convenient 12 volt power. For example, in a garage at home. They told me the fridge runs on 12 volts whether the converter is used or not, and if you have a 12 volt power supply available the 110 converter is of no use and not needed.
Old 07-31-2022, 08:14 PM   #7
Bellpilot's Avatar
Norcold makes a direct replacement NR751
2010 E350 6.0 4x4 EB 50 SMB
Old 08-01-2022, 07:43 PM   #8
I started a new thread
Replace Norcold DE-451 with Norcold NR751BB, Review?
Jeff in Seattle
Old 08-04-2022, 11:39 AM   #9
moorefc's Avatar
Originally Posted by jeff00seattle View Post
Another discussion reference, same models (you may have found in your search) -
https://www.sportsmobileforum.com/fo...ion-28067.html
https://www.sportsmobileforum.com/fo...4&d=1617577070
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 08-06-2022, 11:27 AM   #10
Replaced original RB50 NorCold DE-451 with NorCold NR751.
Reasons for choice:
Same installment dimensions.
Larger interior cubic feet: from 1.9 to 3.0.
Jeff in Seattle
Tags
norcold, refrigerator
