Old 08-22-2016, 09:11 PM   #1
Roof rack noise
Anyone come up with a fix for the howling from roof racks? I can't put an air damn due to led light bar
Huntsalot is offline   Reply With Quote
Old 08-22-2016, 09:15 PM   #2
mikracer's Avatar
Which roof rack do you have?
Old 08-22-2016, 09:28 PM   #3
bajavoodoo.com is where I got it. It's not very high quality . I don't recommend them. Any good brands out there? I'd add affordable but I know affordable means junk nowadays
Old 08-22-2016, 09:51 PM   #4
mikracer's Avatar
I know wrapping a cord around crossbars helps with noise, but not sure if that would help with your rack. I have an aluminess rack and it makes noise at 65+mph.
Old 08-22-2016, 09:55 PM   #5
Hmm I'd like to get a different rack. Sucks spending 2500 for a rack and when you drive down the freeway all you here is it . Do you know of any other brands out there?
Old 08-22-2016, 10:16 PM   #6
rltilley's Avatar
This is what I've done in the past. Spiral wrapping rope or a bungee around the crossbars has cut down on wind noise for me. Bungees could vibrate off so rope is likely better.
Sent from my iPad using Tapatalk
rltilley is offline   Reply With Quote
Old 08-22-2016, 10:24 PM   #7
mikracer's Avatar
I had the Yakima Megawarrior before the Aluminess and I never heard any noise from it. It was also way towards the back so that obviously made a difference. My Aluminess rack comes all the way to the front, so thats why the noise is so noticeable. I think if you get one that doesn't cover all the way to the front, it would make a huge difference.
Old 08-23-2016, 06:52 AM   #8
Huntsalot, can you post a pic of your rack?
Old 08-23-2016, 07:25 AM   #9
The load warrior/megawarriors both have fairings.....
I notice a huge difference in wind noise on my yakima crossbars with and without fairings. I have crossbars on the van and the daily driver.
Here are some typical shapes and associated coefficient of drag (Cd) for each shape.
Less drag=less wind noise....
I'm not sure why the sphere has a range of Cds....I suspect that the .5 number is a cylinder, since airfoils typically are about 1/10th 1/12th the drag of a cylinder....that's why they make fancy bladed bicycle spokes.
It's all about reducing the wake behind the bars.....airfoils put the airflow back together cleanly with little wake.
Yakima makes a snap-on plastic airfoil...you could try that....or fabricate something.
Old 08-23-2016, 07:36 AM   #10
That's good info man! Thanks for sharing.
Esme
Amy V
Dorothy the Van
ohmbaby
