Old 05-17-2019, 07:39 AM   #1
Phred's Avatar
04’F-250 as 4x4 donor to 06’ E-350?
'04 F-250 Super Duty 6.0 4x4, a donor for my '06 E-350 6.0?
I have first right of refusal on a '04 F-250 Super Duty 4x4 with blown motor.
This to convert my '06 E-350 Super Duty 6.0. To 4wd.
Considering the lift on the F-250 that accommodates 35x12.5x17 tires etc would it be right to assume I'd have most of what I need to do the conversion? I do know I can pick up any and all additional needed parts.
I’m interested to know if I can, with modification use the donor's lift, springs, t-case, running gear etc.?
Would I use the front and rear axle to keep the ratios the same etc?
The more I read I guess it wouldn’t be necessary to change out the rear axle? Would the gears out of the truck differential work in the van differential? Since my primary goal is snow and road comfort in the Rockies in winter and not four wheeling, any reason not to just leave the rear end with the springs and all, but making sure the ratios are the same ?. Would certainly save a lot of work I guess.
Would I need to swap out the transmission?
Thanks in advance for any input.
Phred is offline   Reply With Quote
Old 05-20-2019, 06:42 PM   #2
UJOINT's Avatar
Our 6" kit plus the F axle, sway bar, t-case and rear axle (optional, I would keep the stock axle) and you have a 4wd van. The truck axle is a Sterling 10.5, van has a Dana 60 semi float so the guts aren't interchangeable. Email chris@ujointoffroad.com for an estimate.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 05-21-2019, 09:15 AM   #3
Phred's Avatar
F
Perfect, thanks. I now own the donor. Glad to hear “... keep the stock axle” !
I’ll be in touch.
Thanks Again
Vandit
aarcaris
Coddiwomple
Rpence
