Old 07-10-2010, 09:43 AM   #11
4.10's or 4.56's with V8?
About how many miles did you have on your Ford LS?
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 07-10-2010, 10:36 AM   #12
campervanbeethoven's Avatar
Re: 4.10's or 4.56's with V8?
140,000 mi. currently, but I got the van with 120,000 mi. and it was not working then so I don't know when it failed.
campervanbeethoven is offline   Reply With Quote
Old 07-10-2010, 11:50 PM   #13
Glad you like them. Knew you would. You can always go to the next size up in tires if you want to cruise faster.
Current vehicle: 08' Power Wagon
Future vehicle,hopefully: SMB 4x4 RB 50, Purpose built for off-roading & camping, in style of course !!!
TwinStick is offline   Reply With Quote
Old 07-11-2010, 12:01 AM   #14
I have 4.56s and 265 tires, which are ~31.6".
I have the V10, and running at speed is not an issue. 75 is a comfortable towing speed, and when empty dessert roads allow it, triple digits are no problem (not towing) when I have the AT tires on.
Old 07-11-2010, 10:28 AM   #15
NRL
NRL's Avatar
Send a message via Yahoo to NRL
Originally Posted by campervanbeethoven
Update...Went w/ the 4.56s.--- Picked up the van on tues. and just got back from a short trip to Glenwood Springs. Here are my first impressions.
The van is much better on the hills for sure. Going up to the Eisenhower tunnel from Denver we pulled the whole grade, without issue, at the posted speed limit. Vail pass was still a little steep for the 5.4, but we kept up with traffic for the most part. On the interstate I've lost the ability to cruise at 75 comfortably, although short bursts up to 75 and higher are doable, 60-65 seems to be where the van likes to cruise now in OD. Around town and on the "B" roads is where the new ratio really shines. Good passing and merging power and a whole lot snapier off the line. Haven't had the van off road yet but I did drive a little in low range and this thing really creeps along nicely. Can't wait to tackle some jeep trails around the neighborhood this weekend.
All in all I'm glad I went with the 4.56s over the 4.10s, although, I think the the 4.56s are probably better suited for a 35" tire. If your running 33" tires and can put up with the lack of high speed interstate cruising and are thinking of going to 35" tires in the future, then go w/ the 4.56s. If your happy w/ your 33s, then go with 4.10s.
On a side note, when they got the rear diff apart they found the remnances of a ford lsd in there. It was not working and the clutches were eating into the carrier. They fixed it all up and now Ive got both rear tires getting power. Ye haw!
Thanks again for the input...Luke
I heard you might need to get a new carrier if you go to 4.56... Did you have to get one?
Not necessary if you go 4.10.
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 07-11-2010, 06:18 PM   #16
I did get a new carrier for the rear, but the shop put a "thick gear set" in the front so that carrier stayed. I don't know much about the why's or what's on the subject. Maybe somone w/ more experience could enlighten us on the details. ... I have been told there is no carrier swap for 4.10s in any dana 60.
Old 07-14-2010, 11:21 PM   #17
As you add teeth to the ring gear, it gets larger in diameter. After a certain point, some carriers are too small & either need to be ground for them to fit---but you can't grind them that much before they become too thin, so a new carrier is sometimes nesessary. It is usually the case with anything bigger than 4.56's (higher numerically). I am no expert either, but that is the way I understand it. If thats not correct, I am sure someone will correct me.
Old 07-15-2010, 01:13 AM   #18
Bones_GSXR's Avatar
Some axles can have three different carriers depending on the ratios used.
Dana 60 fronts use two
4.56<Higher
4.30>Lower
The 10.5 Sterling Rear just uses one carrier for all Ratios, and the same carrier in Semi and Full Floating rears.
Old 03-29-2017, 12:03 PM   #19
Shaggy's Avatar
Any updates on this thread? I'm considering 4.56 on 14 350 eb 5.4 v8 W/33
2014 E350 EB Quigley 4X4 [HOONIVAN]
2014 FJ Cruiser
Shaggy is offline   Reply With Quote
Old 03-29-2017, 09:40 PM   #20
ranchero's Avatar
Here's my two cents: I did 4:30s with 33s (snow tires). Runs just fine like that. I live at 7000 feet and drive between 7000 and 10,500 feet weekly and I think the power is just fine. I will be going to 35s once snow season is done with.
1990 Syncro Westy
XPCamper/NIMBL on 2007 Ram3500.
A few Cruisers
2006 E350 RB-31 MG Metalworks/UJOR 4x4 swap (on to another)
ranchero is offline   Reply With Quote
Le Moose
Stanvan
Clyde
ormtnbiker
