Old 11-09-2017, 09:20 AM   #1
SteveInLA's Avatar
Can someone identify this? **SOLVED!**
You are looking at the front passenger side wheel of my Quadvan-converted E-350 (essentially an F-350 assembly). Notice that the brake fluid line and what I think is the vacuum line for the automatic 4WD hub or maybe the ABS or speed sensor cable are prevented from entering the coil by a guard, but this mystery line is routed right through the coil. On this one I notice that it has already been pinched. Is it safe just to detach it, re-route it and reattach it?
SteveInLA is offline   Reply With Quote
Old 11-09-2017, 09:23 AM   #2
yes, detach away. just a vacuum line for auto hubs
Old 11-09-2017, 09:36 AM   #3
Do you have auto hubs? If not you can remove it and plug the hole with a bolt.
Nrobert10 is offline   Reply With Quote
Old 11-09-2017, 10:13 AM   #4
SteveInLA's Avatar
Done. The rubber line just pulls off the nipple that is screwed in the hub. No unscrewing necessary. Fixed and thank you!
Old 11-09-2017, 10:14 AM   #5
SteveInLA's Avatar
I do have auto hubs with a manual override at the hub. Very handy!
Old 11-16-2017, 09:12 AM   #6
bet on black's Avatar
if you are removing, remove the whole vacuum line. i think it runs back to the t-case doesn't it?
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 11-16-2017, 09:19 AM   #7
SteveInLA's Avatar
I'm not removing it. I need it. I like my auto hubs and they are working just fine. I just needed the line to not be passing through the coil and getting pinched.
Coddiwomple
Rpence
Otter
