Old 10-22-2015, 09:26 PM   #11
E350's Avatar
Re: Changing steering geometry on a Quigley?
Thanks Bajasportsmobile! According to the converter, Salem Kroger, it is a 2007 F250/F350 axle. Can you tell from the dual opposing Bilstein gas pressurized shock absorbers that I had a problem with Death Wobble?
Even with everything tight in the front suspension!
(I hope to be able to have you convert it to a TTB Dana 50 sometime before I die or you irrefutably retire...)
