Random old thread bump.
I did some research, and it looks to me like the only things that really matter are:
- the vehicle manufacturer's load carrying capacity for each axle
- which can be derived per tire by looking up the RTA (rim and tire association) load inflation tables for the OE tire size and door placard tire pressure
- the tires that you are running (whether fitted by SMB, Quigley or other -- one assumes Quigley and SMB follow the same process for their stickers, which my van does not have)
On my 2002 V10, the Ford tire placard reads:
60 PSI cold front
80 PSI cold rear
and the OE tire size is 245/75 16.
Looking that tire size up in the Toyo copy of the RTA inflation tables gives (per tire):
2480 lb front load carrying capacity
3042 lb rear load carrying capacity
With a new tire size of
285/75 16, the tire pressures that correspond to >= those load carrying capacities are:
45 PSI cold front (2540lb load carrying capacity)
60 PSI cold rear (3110lb load carrying capacity)
Interestingly, the load inflation tables only stipulate D rated tires for the rear at those loads. There's no harm in having E rated tires, of course, and stronger sidewalls are better at resisting off road impacts and rocks.
Toyo load inflation tables: (see p7 for step by step process)
http://cache.toyotires.com/sites/defaul ... nTable.pdf
These should be the same for any brand of tire, because the load carrying capacity relates to the size of tire and amount of air pressure in it. (obviously the tire has to be rated to be used up to a given capacity)
I don't think scaling tire pressures using "lb per PSI" math is a good idea. The tire tables represent some amount of research and calculation.
I think the SMB build out (which adds weight) doesn't change anything. It is like a cargo van carrying a bunch of bricks or tools in the back, it is just extra weight, providing you don't go over the total load rating for the van - which Ford specifies.
I'm currently running 55/60 pressure, so will try 45/60 and see how it feels. But based on what I have looked at above, they look like the correct pressures for 285/75 16.
Incidentally, if you have 285/70 17, the numbers come out at:
45 PSI front (2510lb LCC)
60 PSI rear (3070lb LCC, D rated required)
The only unknown I can see is, SMB or Quigley changes out the front axle, so not sure if that changes anything.
And of course, I'd like someone to prove my approach as wrong.
Disclaimer: if I'm wrong and you kill yourself because of what I posted above, it is your fault for not doing your own research or trusting the tire placards.
