Old 04-12-2011, 12:44 AM   #1
parisdakar's Avatar
Hi-Lift Jack Extreme: 48'' versus 60''?
Does anyone have an insight on the 48 inch over the 60, or vise versa? It seems that the specs are the same for both. The 60 inch model is quite long and difficult to mount in a clean manner (e.g., on the front Aluminess bumper, it pokes out the ends; on the van interior, it can't be mounted upright).
Many thanks in advance! pd
parisdakar
(bryon)
2010 Ford EB E350 4x4 6.0L with SMB Penthouse
parisdakar is offline   Reply With Quote
Old 04-12-2011, 05:02 AM   #2
Re: Hi-Lift Jack Extreme: 48'' versus 60''?
i got the big one
hope i never have to use it
mounted ok for me
Old 04-12-2011, 09:54 AM   #3
Roonie's Avatar
billWilson,
Where did you get those mounting brackets?
Old 04-12-2011, 11:40 AM   #4
parisdakar's Avatar
Ok, I see how you mounted it. Very slick. That looks quite clean. Are those garage-built brackets?
parisdakar
(bryon)
Old 04-12-2011, 12:00 PM   #5
I went with the long version cause there are times when you might need all the lift you can get. Also the gray model is rated closer to vans of our weight.
Lots of info here:
viewtopic.php?f=3&t=4294
Old 04-12-2011, 12:29 PM   #6
aluminess brackets
i belive they stock them
they can go on the tubes, but i liked em better there
(and i couldnt get em level by myself)
bw
Old 04-12-2011, 12:53 PM   #7
parisdakar's Avatar
Thanks for the link to the previous thread, and the mount info.
pd
parisdakar
(bryon)
Old 04-12-2011, 12:55 PM   #8
lactic's Avatar
Are you able to lock the jack to the Aluminess brackets or do you use a cable lock or "other"?
Back to a Build Sheet and a Dream...
lactic is offline   Reply With Quote
Old 04-12-2011, 04:08 PM   #9
Mine is pad locked on but I'm using the Yakama mounts. Those have a bracket for pad locks
Old 04-12-2011, 07:51 PM   #10
oldbonesclimber's Avatar
Cool Mount and Clean install. I'll have to get a set.
Paul
2007 RB50 6.0 PSD Walker Evans Streetlocks, 305X70X17 Terra Grapplers Custom Aluminess Roof Rack, ETC ETC
oldbonesclimber is offline   Reply With Quote
