I like the idea of getting a folding seat and using part of that. I wonder if they make ones that bolt into the stock Ford bases.
I will have to check out Sheriffdoug's thread, thanks for the info.
Originally Posted by SixCardCharlie
You could get a bench that folds forward into a flat position. Then put a platform bed behind the bench that is level with the bench so when it's folded it extends into a queen. Then just throw a tempurpedic pad on top. Or even one of those tri fold sleeping mats. You could even put a mount for a removable table in front of the bench.
This was my bed plan for little bit before I changed my mind.
Basically a diy version of sheriffdoug's check out his engine rebuild thread it's on the first page.
Steve
Sounds like some good ideas, do you have any photos of this? Thanks again.
Originally Posted by Steve_382
We also had a basic van before this one. We installed a couple of teak rails (1"x2") along the walls about a foot down from the roof. We used bungy cords to lash sleeping bags, back packs, etc. to the walls. The bottom of the packs rested on something like the storage boxes mentioned earlier in the thread. Those teak rails worked great and I still miss them sometimes. We stored 4 bikes in the van with the front of the bikes mounted on bike tights on a 2x4 that went from one side of the van to the other about 16" above the floor. We slept on the floor with our feet under the front of the bikes and our heads toward the front of the van. Took some moving around at night, putting some totes in the front seats, but we stayed in it for 4 months straight once touring the west. Carried bike gear, back packs, climbing junk, etc. During the day, the totes went under the front of the bikes where our feet were while sleeping.
Edit: Forgot to mention that we had 4 captains chairs in the van when at home, but removed them when traveling.
Weekends are meant for being off road!
I did some google research and came up with some decent builds I combined into one image. I really like the one with the kitchen table but not sure I have enough room for that unless I pulled out the bench seat (and skills to build). The larger bench/ bed on one side that flips over to connect to a smaller bench to create a removable platform bed could be a good idea. I can have storage underneath and flip it up if I am alone or need to use the van for hauling.
It's hard to say but I think it's equivalent to a standard double width. I bought 4 pieces of high density foam that were each about 2.5 inches thick. Then I used upholstery adhesive to join 2 of them together to make 2, five inch thick mattresses. I had to trim the ends to get them to custom fit the platform. I'm 5'9" and just fit sleeping crossways. The foam pieces were $20 a piece, so I'm only into to it for $80 total.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
It was arranged a little differently on this trip, but here are a couple of pictures.
