Old 07-27-2009, 10:22 AM   #1
pjpvi's Avatar
Limit straps
Has anyone installed limit straps on the front axle of an SMB 4x4 conversion? I'm convinced that is the root cause of my failing spring / shock mount plate a couple weekends ago.
For anyone that has installed them, where and how did you mount them (any pictures would be great)? I have some ideas of how I will do it, but I am curious what others have done. I may also install them on the rear. I know the rear axle can drop further than the reach of the shocks from watching Deaver do some additional work a few weeks back.
Thanks -
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 08-15-2009, 11:02 PM   #2
Re: Limit straps
These work well because it's hard to set it up right (where your getting all the travel you can without blowing shocks), and they are adjustable.
https://www.polyperformance.com/shop/Si ... -1841.html
Here's how they mounted them on a Ranger.
scoobasteeve is offline   Reply With Quote
Dodge
lugee
GIL
Manoel Brazil
