03-09-2015, 11:38 PM
Re: Tire and Wheel Gallery
The popular combo of ATX Mojave Teflon and 285/75/16 BFG AT. SMB 4x4 conversion so 4-6" of lift depending on age...
No rubbing ever, even when flexed and turning full-lock.
03-10-2015, 12:41 AM
Here my 2001 with 37" BFG-MT on 9" Mickey Thompson
about 3-4 inch lift as i want to keep the van as low as possible so
front and rear fender had to been cut to prevent the tires scratching while twisting
www.Dieda-unterwegs.net
03-10-2015, 10:03 AM
I certainly can't be one to talk here, but have another suggestion to avoid mucking it up. If you're going to quote, please delete the image from the quote, which duplicates the same images over and over, or just avoid the quote completely and call the person by name and then add your comment. I'm trying to avoid commenting on awesome rigs I've seen here for the first time.
example: Hey tlg, awesome rig! Hey schluchtenflitzer, yours too!
03-10-2015, 10:37 AM
Originally Posted by eddyturn
Originally Posted by MKRyan
I just have to say that looking at your van makes some lower body parts on me start to tingle.
Er... Eddy? Don't tell us everything, a little mystery is okay, bro...
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
03-10-2015, 11:29 AM
this thread is a great idea! however imho, there no reason to post any info if you dont have it all for a thread like this. wheel fitment is a lot more than just buying a wheel. offsets are very important to get the look you are after and the incorrect offset can ruin how good a wheel can look. all reputable wheel companies should have the offset either on a label with all other stats, or stamped on the backside of the wheel face or barrel and will look similar to this.
if your posting, please include wheel size (diameter and width), load rating, and offset along with brand names. it would also be helpful to other to know if you are using wheel spacers or not.
03-10-2015, 05:51 PM
And here's another... WELD Racing Forged 16"s with 285/75/16 Toyo AT2s. Been real impressed with the AT2s for traction and road noise.. Wish I went ahead and trimmed the already trimmed fenders a bit more to clear the 295 AT2s which come in the Extreme version (even deeper lugs, similar AT tread pattern).
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
03-10-2015, 11:24 PM
Here is what I run on. They are Ultra Wheel 195 Crusher Satin Black with Diamond Cut Face wheels. The specs are 18 x 8.5" with a 12mm offset and a load rating of 3250 lbs. The are wrapped in Mickey Thompson Baja MTZ Radial LT275/70R18 (33x11.5R18) tires. Their specs are Load E rated, 80 psi, 3640 lbs, Rim Range 7-9", Section Width 11", Tread width 8.8" and an overall diameter of 33.4". I like the tread pattern. It doesn't seem to pack up with mud but will grab the occasional small rack and hold onto it. The van has a 4" lift. I get a slight rub when fully articulated at the back of the front fender when turning. It has never presented an issue.
Cheers
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
03-11-2015, 04:36 PM
There are some great suggestions here so far!!
alta, do you happen to know the name of the weld wheel above? I went searching and could not find it, though I love the wheel!!
Thanks so far all!
Please, Keep em coming and I will be sure to add my version once I get it figured out...
George ><>
03-11-2015, 05:40 PM
Skyrat - I have no idea on what model # they are, haven't been able to find them online at all. I do know they are from '02ish - took awhile to track down a matching black center cap to replace one which went MIA on my maiden trip home
03-11-2015, 07:11 PM
#20
Eagle Alloy 050 series
Big O Bigfoot AT 285-70-17
I chose the Big O tires after researching all the big names. Better warranty, better price, made in the USA. Been really pleased so far.
Quigley 4x4
