Old 03-31-2012, 07:34 PM   #11
Re: Winches...again
I need to take a few of finished project.
carl
2010 SMB
Old 03-31-2012, 08:02 PM   #12
Re: Winches...again
Superwinch install beginning video....
carl
2010 SMB
Old 03-31-2012, 10:16 PM   #13
Gnarvan's Avatar
Re: Winches...again
Why did they pull the grill and the headlights off to install a winch? Were they installing other things too?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 03-31-2012, 11:03 PM   #14
BIGVANS's Avatar
Re: Winches...again
As far as a hitch receiver mount style, I’ve never seen a hitch receiver winch mount plate rated at more than 9,000. Have you guys?
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 04-01-2012, 05:48 AM   #15
Re: Winches...again
"As far as a hitch receiver mount style, I’ve never seen a hitch receiver winch mount plate rated at more than 9,000. Have you guys?"
I looked as well and 9000 was the heaviest I could find.
Old 04-01-2012, 10:32 AM   #16
Re: Winches...again
just posted a few pics on my gallery
carl
2010 SMB
Old 04-01-2012, 12:22 PM   #17
Gnarvan's Avatar
Re: Winches...again
After looking at the picture I can see why they had to pull the grill. The grill hangs out over the bumper partially covering the winch compartment.
With the winch installed can you still get the lid back on the winch compartment?
When I installed the 12.5SR in my bumper I got rid of the plastic solenoid housing and bolted the relays and solenoid directly to the inside wall of the winch compartment.
Remote solenoid, relay and remote plug location
I used the side your winch electronic pack is located to bolt in the relays and fuses for the driving and fog lights.
I also rigged up a fairlead cover to help keep road splash off the synthetic rope.
If I had it to do over again I would probably get 2 more light mounts from Kenny and mount all three lights up high. Having the two side lights that low to the bumper makes it real tight to get the winch compartment lid off and on.
John
Old 04-01-2012, 02:16 PM   #18
Re: Winches...again
We had to remote mount solenoid taking off the backing plastic which is what normally mounts to the winch itself. Then using its own bracket we mounted it on the right rear wall of the bumper with three screws so it is solid. I also wanted it easier to connect winch controller so we moved it up as high as possible so that cover would still go on. Also re-routed the air chuck higher so it is easier to use.
carl
2010 SMB
Old 04-02-2012, 10:37 AM   #19
Re: Winches...again
Originally Posted by Bbasso
How about a cheap, light, easy solution that can fit under your seat?
Sure it would require you to actually work, but as many others have said they rarely use the electric ones so it would hardly be used...
Having used one of those to recover a Scout from light mud... ah, no. That's a backup tool for holding a vehicle while you recover it from a side hill maybe, or stretch fence. Hi-Lift is 10x better, however you have to reset a lot and still doesn't compare to a winch.
