Plus you can plug in at any koa type campground etc, specifically you should look at the Coleman Mach 8(pretty sure going from memory) it is designed for desert up to 110 degrees other units just can’t keep up! Plus it has dual motors so you can use one at night and not so noisey! If you don’t sleep good doesn’t matter how beautiful your surroundings are plus can lead to a divorce if not by your wife the dog may retain an attorney!
