Old 04-15-2009, 10:02 AM   #1
Porta Bote side mount for Hi Top Sprinter
My Porta Bote is 128 inches long and about 4 inches wide when folded up and will JUST fit on the drivers side of the van without impinging on either the drivers door or the tail lights. How to mount it is a different question.
Any brilliant ideas out there besides getting a REAL boat?
Got my answer thanks to a SMB poster.
bassman is offline   Reply With Quote
Old 04-15-2009, 12:34 PM   #2
Re: Porta Bote side mount for Hi Top Sprinter
Bassman ,
Porta Boat offered carriers in the past that were designed expressly for the side mounting on vans and RV's . www.porta-boat.com
Greggde
Old 04-15-2009, 03:01 PM   #3
Blackeye's Avatar
If you still need something, check with Dave and or Travis at Aluminess Products. They could figure something out that would be light, strong and look cool.
http://www.aluminess.com
Best of luck with the mount.
Blackeye
"I wonder as I wander out under the sky..."
In between rigs at the moment.
https://www.overlandtraining.com/ Overland Certified #OC0008
Blackeye is offline   Reply With Quote
Old 04-17-2009, 10:53 PM   #4
cellularSTEVE's Avatar
do you want to mount it like this?:
steve
Old 04-18-2009, 08:32 AM   #5
That's about it except I have a short Sprinter. Are the miunting brackets from Porta Bote or did you do them yourself?
Old 04-18-2009, 09:17 AM   #6
Bassman,
My SMB is the one in the background with the Portabote on the roof.
However I have what looks to be a similar side mount aluminum bracket that I use to mount in my garage. It came from Portabote, so you can contact them directly. Here is probably what you are looking for (scroll all the way down):
http://www.porta-bote.com/rvmounting.html
hope this helps.
steve
Old 04-18-2009, 10:19 AM   #7
I already talked to Porta Bote. I'm trying to figure out a way to not have the brackets sticking out when I'm not carrying the boat. I was thinking of steel or aluminum brackets that hung down off a roof rack and could be removed easily. The Porta Bote brackets are also very costly.
Old 04-18-2009, 11:32 AM   #8
Bassman
I have a friend with a Winnebago sort of thing, and he carries his Port A boat on the side by having two small padeyes from West Marine top and bottom, fore and aft, and uses two ratchet straps to secure the boat. When the boat is not on the rig, the little padeyes only stick out about a half inch or so.
Bill
NO2B
Old 04-18-2009, 11:36 AM   #9
Footman loops would be a good substitution, unless that is what you mean by padeyes. I have several 1 1/4" footman loops if you want to buy 4 or 6.
Old 04-18-2009, 11:43 AM   #10
Bassman
Go to http://www.westmarine.com and look under padeyes or eye straps- there are a million. The ones my friend uses are part # 477836. But you can look at tons of others. Be sure to mount with a backing plate behind van side to distribute the load.
The tiedown straps are (I think) part # 8725624.
Bill
NO2B
