Old 02-05-2010, 07:30 PM   #31
Re: 2wd chevy van lifted 15" Cummins Turbo Diesel power
when i bought the van it Registered as a Commercial Vehicle the fee where $260
i install 4 Captain's Chair and a bench seats now is Registered as a sportsvan the fee drop
to $160 i changed from gas to diesel no smog test
Mr1974van is offline   Reply With Quote
Old 02-06-2010, 08:34 AM   #32
We not only have to emissions our Diesels here, we have to do it annually instead of bi-annually for gassers.
Old 04-27-2010, 02:26 PM   #33
texas longhorn
Old 04-27-2010, 03:13 PM   #34
SteveInLA's Avatar
Of course your next accessory has to be this, if it isn't there already (WARNING! NSFW-ish)
SteveInLA is offline   Reply With Quote
Old 05-11-2010, 09:56 AM   #35
Ok I have a B250 dodge van and I would love to know how to do a similar lift and nobody seems to be able to help me I already know the ram truck stuff id different but still want the lift....any ideas?
chromekid01 is offline   Reply With Quote
Old 05-11-2010, 10:57 PM   #36
Read my response to your other thread. Also, I think eventually you'll have to buy fit and/or fabricate, or be willing to do so or pay someone to do it. I'm one to talk, I bought an 8" lift for my Cherokee that never fit because the tranny mount for my year was in the wrong place. It sat in my garage for 4 years and I eventually put it on a Comanche, which required some mods, but not as much as would have been for the Cherokee.
Old 06-25-2010, 05:39 PM   #37
Hard hard to put a Cummins in?
So back to the big point, how hard is it to put a Cummins into one of the vans? Would the 6bt (I think that is one of the newer Cummins engines) fit into the Econoline chassis? Anyone try this?
supermoo is offline   Reply With Quote
Old 08-29-2012, 05:39 PM   #38
started workig on 4 link on the van with ford 9" 373 gears
Old 08-29-2012, 06:30 PM   #39
Re: Hard hard to put a Cummins in?
i just finish installing a 4bt cummins with turbo 400 in to a ford van e350. it was a lot of work i think the owner is going to start topic
Old 08-29-2012, 08:55 PM   #40
BIGVANS's Avatar
What about upgrading to disc brakes?
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Big Backpack
RMAC
Priscilla
DocMP
