Old 03-14-2017, 10:05 PM   #1
Flyview's Avatar
Question Alignment specs
I have an E250 2WD SMB that I've put 17x9" ET-12 rims on, so they stick out quite a bit more than stock (with 245/75/17 tires). I was wondering what alignment specs you guys like to run and what you would recommend for me.
Flyview is offline   Reply With Quote
Old 03-15-2017, 09:45 AM   #2
I thought we had a Sticky with that kind of info, but I can't find it at the moment.
Old 03-19-2017, 05:59 PM   #3
Flyview's Avatar
Please update the thread if you can find it. I did a quick search and couldn't find much related to wheel alignment.
Old 03-19-2017, 06:14 PM   #4
FWIW, this thread includes the alignment specs for my '06 E350 SMB, from when I replaced my tie rod ends.
http://www.sportsmobileforum.com/for...ends-1995.html
Old 03-20-2017, 11:55 AM   #5
Flyview's Avatar
Thanks, I just read through it!
It brought up some interesting questions for me.
I didn't realize SMB may have altered the suspension/steering components. It seems this may have just been for the 4x4 version (mine is RWD). Unless one of you can confirm for sure, I think a call to them is in order to figure out exactly what they changed from stock when it comes to the vehicle mechanics on my 1992 Ford E250 EB.
Edit: I spoke to them. There are no mechanical changes made by them on the 2WD models.
How is front camber adjusted?
Is front castor adjustable?
What's adjustable in the rear?
Should I just go with the stock alignment specs even if my wheels have a wider track now?
It's a little worrisome that the PF wheel has a bit of positive camber whereas the DF wheel has a bit of negative camber (at least it looks like it to me).
Any more info to answer these questions is appreciated!
Old 03-20-2017, 11:57 AM   #6
Mine was for 4x4.
