Old 12-21-2017, 01:50 PM   #11
MSD
MSD's Avatar
Originally Posted by StraightOuttaBallard View Post
So nobody runs these?
Nope, mine are on the same as 1der and mine have been on for 10 years plus no galvanic corrosion. Van has been in all weather conditions on both coasts and has been an out door stored van for the last couple of years.
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 12-21-2017, 04:00 PM   #12
The honeycomb crush isolator seem to be more to protect the bumper rather than the frame's crumble zone. I smashed into a highway guardrail towing my trailer, and while the bumper bent, and hundreds of feet of guardrail was remodeled, the frame was fine. Since both the bumper and the frame are painted, adding an additional barrier probably is overkill.
Old 12-21-2017, 11:08 PM   #13
I'm headed into the de-icer, sand/grit/gravel laiden zone of the Powder Rogers Pass, BC among others possibly the Rogers Pass in MT. also.. at the end of winter drive to Valdez SC Ak etc
Our routes sound similar. Clearly, were headed into the corrosion zone, and I've been there many times. I'm far more worried about corrosion on things like the frame, the gas tank, the suspension, actually... pretty much anything metal under the van, than I am about the frame horns. My regular plan is to wash the undercarrage as often as possible, normally at the end of each trip. In the spring I treat as much rust as possible with some type of conversion product and then paint. Rust is going to happen no matter what we do, the trick is to stay slightly ahead of it. If an isolater pad helps a tiny bit, or provides a miniscule additional amount of impact force absorbtion, I see no reason not to run them if you want to, but personally I don't think its a big enough difference to matter much.
Old 01-12-2018, 12:54 PM   #14
Tracker926's Avatar
I have been running the Aluminess front bumper on my 2012 E150 four years now. No isolators and no corrosion between bumper and crush area.
Tracker926 is offline   Reply With Quote
