Old 12-21-2017, 12:09 AM   #1
StraightOuttaBallard's Avatar
Ford bumper isolator w/an Aluminess front
Hi -
I have a question for the E- series folks running a front Aluminess bumper.
Did you use the Ford bumper Insolators?
The local Ford dealership gave me these as part#s -
RH 710C 882A, LH 710C 883A suppose to be the rubber waffle type expanded material.
This all started when local Ford said I needed these (found cheaper here)
I'm almost where I wanted to be when posting pics...
Just about have the wiring done for the led's got the rear on one some other things... This reminds me of J.E.E.P = just empty every pocket
Ha ha funny thing is I'm about 8 months behind schedule
"A determined soul will do more with a rusty monkey wrench than a loafer will accomplish with all the tools in a machine shop."
White Buffalo - 2002 E350 4x Quigley 7.3 PSD... 52k mi
StraightOuttaBallard is offline   Reply With Quote
Old 12-21-2017, 12:52 AM   #2
1der's Avatar
Aluminess Bumper mounts right to the frame horns, no isolators.
Old 12-21-2017, 12:59 AM   #3
What I don't follow is that it looks like to me in a strike to the bumper at high speed hit would damage the I Beam front end
Old 12-21-2017, 07:18 AM   #4
That's not the I beams......the convoluted holes in the front frame are the crush zone to absorb the impact energy of a crash...they are designed to be damaged.
Old 12-21-2017, 08:02 AM   #5
Is this section repairable? weld on? bolt on?
Are you guys running these: https://images-na.ssl-images-amazon....L._SL1000_.jpg
Old 12-21-2017, 08:51 AM   #6
These two engineering concepts boggle my mind in this application:
1. A love tap Al bumper bolted to Steel w/o any dampening equates to a dent or a bend - deflection of some sort some where.
2. Aluminum bolted to steel w/a a gritty interface spells electrolysis ... oxidation via galvanic action... Are end users at least installing rubber gaskets where they mount the bumper?
Old 12-21-2017, 09:26 AM   #7
I don't think there is anything you could place between the frame and bumper that would reduce the damage from a high speed crash. Something is going to give, bend, crush, get destroyed. The wrinkles in the front of the frame are designed to reduce / absorb some of the forces before they get to the passengers. Unfortunately, many 4wd conversions weld or bolt leaf spring hangers to the front of the frame, pretty much eliminating the crush zone. Isolaters may reduce galvanic corrosion between aluminum and steel, but unless the bolts are isolated too (perhaps through plastic bushings and washers) there is still a conductive path that would allow corrosion to take place, but I have never heard of any issues.
Old 12-21-2017, 09:30 AM   #8
1der's Avatar
We just pulled off our front and rear Aluminess bumpers in the last couple of weeks after a couple of years of them being mounted. This period covered six week each plus ski trips around the western US the last two seasons with road crap, etc. and four weeks in Baja, plus the van living outside in San Francisco.
There was no electrolysis present anywhere. If you hit something hard enough, the first dent and deflection will be the bumper. If the hit is enough that frame has damage, I would think there would be major body damage elsewhere.
Old 12-21-2017, 10:36 AM   #9
So nobody runs these?
Old 12-21-2017, 10:41 AM   #10
I'm headed into the de-icer, sand/grit/gravel laiden zone of the Powder Rogers Pass, BC among others possibly the Rogers Pass in MT. also.. at the end of winter drive to Valdez SC Ak etc
