Old 02-24-2017, 09:39 PM   #1
Flux's Avatar
Newer Style Dash Removal
What's the secret?? I had to flex it to get the deep part away from the gauges. Column is all the way down. Maybe the shifter??
And each Quick disconnect is it's own special little puzzle. I'm just hoping not to break anything.
<br>
Old 02-25-2017, 01:56 AM   #2
I had to unbolt the steering column. The short pig tail on each connector makes it a pain no doubt.
Two 7mm screws holding the diagnostic port, four 13mm nuts holding the steering column (be sure to support it while you let it drop some). And I believe three hard to reach screws holding the climate control panel to the main front panel.
Brianjwilson is offline   Reply With Quote
Old 02-25-2017, 09:17 AM   #3
Flux's Avatar
Thank you much!!!! That did it!
<br>
