Old 10-28-2007, 06:45 PM   #11
The van uses both water temp and throttle position to determine when to turn on the fan.
Frequently above 190 and always above 215 I can make the fan come on and go off by changing the throttle. It was worrisome at first, but now I just tell myself that it is working correctly.
Old 10-28-2007, 07:17 PM   #12
mmocken's Avatar
Send a message via AIM to mmocken
Re: Engine fan
It appears you engine is de-rating...possibly from a false partial overheat. Check our your overflow bottle for low coolant or replace the temp sensor.
Of course...I could be wrong
Originally Posted by myriadmyriad
Mike I thought the factory programmed the fan to come on at 215.
Mine comes on (sometimes) when the engine is cold, less than 100 degrees.
I have a ScanGage... The fan comes on anytime it feels like it.
190,200,215,227. Anytime theres a slight grade it hits 215.
It sounds like, from other post, the fan does come on alot.
When the fans on full it seems like I lose 40 horsepower.
I still want to take off the front bumper and see what happens...
Take care
JM
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 10-30-2007, 11:07 PM   #13
Buji's Avatar
Re: Hood scoop
I thought of a hood scoop, but I think it might let in too much water.. I put louvers in the hood and on the side front fenders. I also put a scoop under the bumper.
JM
Did you put the louvers in yourself? Some sort of puch or technique? I saw louvers on a GTRV van that had a cummings diesel in it, and they were not the typical "cut a rectangular hole and mount a louver plate over it"
I'd like to get louvers on the side, gill style
-Buji
_________________________
Modified EB-22 with Penthouse Top
https://www.sportsmobileforum.com/alb...43791a54be.jpg
Buji is offline   Reply With Quote
Van22
Van22
Ann the Van
Bongo
