EB Van Driver Side Steel Window Panels
I am having a set of these made up to replace the 2 back glass windows on my van. There is enough on the steel sheet for a second set. (picture is of the templates I dropped off at fabricator today, back side has bolt locations)
Made from 10 gauge steel. On the large panel there will be (12) Grade 8 - 1" - 5/16th bolts welded to the back around the perimeter about 2" in from the edge. The small panel will have 6 bolts around the perimeter.
Looking for about $250 for the set, you paint or powder coat as desired.
Obviously pickup only around the San Luis Obispo area, I am in Atascadero
Home Built Camper Van - 2003 EB 15 Passenger, 7.3 PSD, Ujoint 6" Lift, 35x12.50x17E BFG AT KO2 , MSD High Top, Hand Made Interior
