Old 05-22-2014, 10:08 PM   #1
"Holy Grail" Help, how much ?
So, I may have an opportunity for the "Holy Grail" 7.3L with 100K and SMB 4x4 conversion. EB50 floor plan with a bit of wear and tear, bumpers front and rear, propane but no cooktop & full service records.
What do y'all think would be the right price?
thanks
martkuhn is offline   Reply With Quote
Old 05-22-2014, 10:11 PM   #2
mikracer's Avatar
Re: "Holy Grail" Help, how much ?
There was one recently on CL that came with a SMB trailer and it was listed for $56k. It must have sold because the ad was deleted. It was that desert sand color too.
Old 05-22-2014, 11:42 PM   #3
Check out the one listed right here in this forum by debmaz as a comp.
It's a loaded 7.3, higher miles, but geez, compared to the one mentioned above for $56, this one is a deal.
gbail is offline   Reply With Quote
Old 05-23-2014, 08:25 AM   #4
E350's Avatar
Just a head's up. It is only the "holy grail" if you are willing to learn about your engine and do the maintenance and preventative mods yourself. Which can be quite interesting and satisfying. Otherwise it WILL be a money pit.
Old 05-23-2014, 08:36 AM   #5
Whatever they'll sell if for? 40K? What are you willing to spend to not have the 6.0L?
I don't actually think that's a good comp, it's a 2000 with Quigley 4x4 and double the miles, the bumpers aren't Aluminess, I'd call the interior the opposite of wear and tear, and it's not an EB50...
Old 05-23-2014, 08:07 PM   #6
Not sure how much the asking price is on the one you're looking at, but here's another one. Not sure if it's the 7.3, but a damn good price for 55k miles.
http://denver.craigslist.org/cto/4462233609.html
bphin is offline   Reply With Quote
Old 05-23-2014, 09:00 PM   #7
E350's Avatar
Here's the VIN Decoder:
http://www.ford-trucks.com/forums/vindecoder.php
That is a good looking van. It is a V10.
See attached pdf
File Type: pdf VIN Decoder - Ford Truck Enthusiasts Forums.pdf (272.2 KB, 5 views)
Old 05-23-2014, 09:12 PM   #8
Just like Jage said, it all depends how bad you want the 7.3 and don't want the other options.
But, with any 7.3 approaching or around 100k miles make sure you have $5k in savings for the Transmission set aside. And as great as diesels are, I love mine, they are pricey to fix.
1995 SMB Quigley 7.3 EB
"a quality, stock 460 is a real pleasure" - twogone
blupaddler is offline   Reply With Quote
Old 05-23-2014, 09:14 PM   #9
Zeta's Avatar
My concern with a 2003 SMB conversion is that it will be an extremely early effort for them. How well were they done? How many bugs were there? My '06 had upper spring plate failures, what issues did the earlier models have?
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 05-24-2014, 09:03 AM   #10
Thanks everybody for the input, some of my concerns have been echoed in the replies. I did experience some problems with shifting the atlas transfer case, don't know if it's because it has been rarely put into 4wd or what?
Milkracer, it is the one that was listed in Newport that included the trailer, the prior buyer fell through.
