Old 03-24-2013, 11:34 PM   #11
AndrewST's Avatar
Re: Help Sourcing Flexible, Adhesive-Backed ABS or Whatever.
Thanks.
Do you have the full reference of the product by any chance?
Old 03-24-2013, 11:40 PM   #12
deminimis's Avatar
Thanks for the offer Pat. I'll probably just grab some of the 3M stuff as that's what I'll likely end up with.
Old 03-26-2013, 10:10 AM   #13
AndrewST - It only says "Avery UHA". I measured my roll and it is about 48' long which would be enough for a penthouse application, It must have started as a 60' roll. PM me if interested.
Pat
PatO is offline   Reply With Quote
Old 04-04-2013, 08:46 AM   #14
I used the Avery UHA as well, from SMB West. I have a foot or two left after doing the EB PH. I'm pretty sure I used some on the kick panel of the Jeep after too. It's nice stuff, repositions well when you don't get that long body edge right the first time.
UHA stands for Ultra High Adhesive.
Old 04-04-2013, 11:12 AM   #15
BrianW's Avatar
$57 on sportsmobilestore.com:
http://www.sportsmobilestore.com/pentho ... tive-tape/
Old 04-04-2013, 11:19 AM   #16
deminimis's Avatar
I ordered up the 3M version today (1" wide test roll). It's too narrow for my application, but it was cheap enough at 1" wide to buy a roll to check it out. I'll have plenty left over Andrew as it's 12 yds. The thickness might be a bit thin, however. (15-20mil if I recall). I can't recall how thick the Avery stuff is.
