Re: Eli's Awning Brackets
Originally Posted by surfgeek33
Did you have to bend the brackets for the PH clearance when its down?
Didn't have too. But it's close, real close.
It possibly would be a problem if you had an electric Penthouse since I manhandle / benchpress my penthouse with two solar panels manually; sliding it to the left or right.
I had to be careful and avoid the brackets by moving the Penthouse coming down to the right clearing the brackets, then move the penthouse in closer left.
I can't see how any bracket design would not do any damage if you 4x4, either with our without the awning itself.
I plan on slipping off the awning from the brackets and removing the brackets too when done camping..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
