Old 01-06-2018, 06:34 PM   #21
MountainBikeRoamer's Avatar
Originally Posted by NavyNuke View Post
Having run a lot of 2wd, you could probably do the entire route, but at what cost in body damage/broken bits
Not sure I'm fully understanding ya....
....only thing I can think is that perhaps you are implying that (compared to a 4WD), a 2WD van would have to go extra fast through the same areas to avoid getting stuck....and it's that extra speed that would potentially cause body damage / drivetrain & suspension strain.
If instead you're thinking that body damage to a 2WD would be a result of low clearance, then I should clarify that I'm talking about 6" lifted 2WD vans with 33" tires (such as a Camburg, WeldTec, Action Van setup.) Similar tires/height/clearance/approach & departure angles to an Agile 4WD setup.
Mike T
___________________
'95 Ford E250 RB30 PH
Old 01-06-2018, 07:07 PM   #22
Marcel Huijser's Avatar
Cost is definitely per van.
I think the number of people per van is limited to 2, but check with Rachel and Bill to be sure.
Marcel Huijser is offline   Reply With Quote
Old 01-06-2018, 07:16 PM   #23
One of the biggest advantages with 4WD is the low range on the t/case. Even with 4wd, I came down Sheep Canyon at Anza Borrego in my Bronco when I had the stock t/case and a Ford 4 speed top loader transmission. Driving a manual trans without low gearing meant riding the brakes and the clutch an awful lot (19:1 crawl ratio). When I went to an Atlas t/case and a ZF 5 speed, it was a WORLD of difference (100:1 crawl ratio). Of course this is MUCH more significant and challenging with a manual trans.
Regardless, don't let 2wd scare you of the trip. If nothing else put in a call to Rachel and she'll get in touch with Bill and ask his advice.
BroncoHauler is online now   Reply With Quote
Old 01-06-2018, 07:21 PM   #24
rltilley's Avatar
I contacted Bill and you guys are right. The price is per vehicle. I don't ask how many per vehicle are allowed. I put down a deposit and I believe the class is now full. Just need to convince the wife that this will be a fun thing to do...
Sent from my STV100-1 using Tapatalk
rltilley is offline   Reply With Quote
Old 01-06-2018, 07:36 PM   #25
Originally Posted by rltilley View Post
... Just need to convince the wife that this will be a fun thing to do...
Bill is so easy going, you can't help but learn and have a great time. Not intimidating at all, and your wife will enjoy the class as well.
Old 01-06-2018, 10:30 PM   #26
Bill Burke confirmed that the class is now full.
Old 01-06-2018, 10:33 PM   #27
Gooseberry's Avatar
It’s a great class but at that cost I might just start doing classes myself for fun and help people get comfortable with the vans off-road.
Old 01-07-2018, 10:14 AM   #28
NavyNuke's Avatar
I was referring to the speed to avoid getting stuck, and possibly different lines for the 2wd.
Need to get a locker in my van still too!
Sent from my SAMSUNG-SM-G891A using Tapatalk
NavyNuke is offline   Reply With Quote
Old 01-07-2018, 02:07 PM   #29
vandiesel's Avatar
Do it gooseberry!
Old 01-07-2018, 05:41 PM   #30
adventurevan5's Avatar
Just spotted this thread, sounds like a very cool learning experience. Someone type in its full is this correct? Thanks
adventurevan5 is offline   Reply With Quote
Tags
4x4, burke, class, training, trip
Malbec
brushogger
Margot
FCAshevlle
