Old 05-20-2009, 12:24 PM   #1
SMBDAD's Avatar
Brake job advice
I am looking to upgrade front rotors, pads, brake lines, and shocks. I called Quigley to see what parts reference to replace. They said they rotors were specific and machine to alow the abs sensor to remain. Has anyone changed/ upgraded to a more stock part that is easier to obtain. I am willing to change the rims if needed to do this. Going back through quigley will be time consuming and expensive. There is also the draw back of breaking down/ servicing on the road. Any help would be appreciated.
2001 7.3 4x4 "Land Orca"
SMBDAD is offline   Reply With Quote
Old 05-20-2009, 06:40 PM   #2
Greg In Austin's Avatar
Re: Brake job advice
I think your idea to move to more standard parts is a good one...
Did Quigley offer any suggestions on what your options might be? (other than another special made part)
Greg in Austin
Old 05-20-2009, 08:55 PM   #3
I believe that Quigley uses stock F-series axles, so I would guess you should check your year against F-350s with ABS and see if you can find a compatible roter. I'm guessing the ABS comes from the van and was added to the new axle, so I wonder if you could change sensors to the F-series as well and get a better fit.
All speculation, I'm far from a Quigley expert.
Old 05-23-2009, 01:18 PM   #4
I went with Brakeman and am very happy. There are other similar companies.
http://www.thebrakeman.com/home
If something fails in the field, I was told stock can be added to get me home. I have yet to upgrade my lines to stainless but was told that also was an important factor and should be done. Its another "one of those days" things.
"Campy"
campy
99 Ford
dogredsurf
