Old 09-23-2010, 09:49 AM   #11
Re: Fender Vents (etbadger mod)
Awsome mod & awsome job !!!
Current vehicle: 08' Power Wagon
Future vehicle,hopefully: SMB 4x4 RB 50, Purpose built for off-roading & camping, in style of course !!!
TwinStick is offline   Reply With Quote
Old 09-24-2010, 05:45 PM   #12
Saline,
Are the vents you used curved to fit the profile of the fender, or does the plastic bend enough to fit the profile of the fender, or is the location essentially flat?
thanks,
[EDIT: Oh, and about what size are those vents?}
The vents are curved a bit but a are flexible enough that they conform to the shape of the fender. The vents are 16"long and 6" high at the tallest point.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 09-24-2010, 06:49 PM   #13
Thanks for the info. Now if I get serious, I have to decide between those, and these metal ones. At 2-11/16" x 12-1/4", not nearly as large as yours, but I like that they're metal.
Note, this is a company pic from their website showing their louvers against a Jeep fender, but you get the idea.
http://www.raceace.com/products.html#productsside
Old 10-06-2010, 07:41 PM   #14
So, any update on the temperature situation?
Old 10-07-2010, 08:19 AM   #15
stikine's Avatar
You did a great job - looks good. What did you use to cut through the fender - a offset grinder?
2007 SMB White 4x4 RB50 6.0l Diesel PH, Toyo 295/70/17 M/T E
https://www.ecotonephoto.com/
stikine is offline   Reply With Quote
Old 10-18-2010, 06:44 PM   #16
Nope not yet sorry. I haven't had a chance to check out the temps yet. It does seem that the engine fan does not stay engaged as long during climbs etc.
Also I used an angle grinder to cut the opening and then a Dremel to clean it up a bit.
Desert Solitaire
2003 7.3L EB 4x4
