04-15-2018, 10:32 PM
#231
Door Talon
Ray do you currently have any available? Do you think they will work with the fiberglass fenders on a pleasure-way Traverse?
Thanks!
04-15-2018, 11:05 PM
#232
I do have them available! Pretty sure it should work. If you can post a picture of the passenger wheel well, especially looking up. Thxs!
04-17-2018, 09:18 AM
#233
Talon
Pics! Let me know what you think? Concerned that it it may not clear the fiberglass flare? I have not seen one in person yet, I can check out MountainBikeRoamer's ride once he has it mounted.
Thanks,
Mario
04-17-2018, 09:37 AM
#234
Hi Mario, Okay, the talon does not look like it will work with your flares. The flare comes down past the stock fender lip quite a bit, at least the way I am interpreting the pictures.
The Talon hooks over the stock metal (and Bushwacker, if used) lip.
04-17-2018, 11:09 AM
#235
I have similar fiberglass fenders. Currently, I have a small hole drilled into the fender for the door talon hook to grab, and it works-sort of. The problem is that the fender sits out further than the lip, which means that there is little-to-no tension in the system, and the tension helps keep the door talon engaged. Mine pops out all the time. I'm getting ready to just cut a slot in the fender so I can engage the hook properly. Function over fashion.
04-17-2018, 04:59 PM
#236
Ray and MorieSugg good info, thanks
I'll give my option some more thought.
04-17-2018, 07:57 PM
#237
How can I order one?
2000 E350 Cargo PSD w/ UJOR 6" Lift
06-04-2018, 09:03 PM
#238
I ordered the door talon several months ago and finally got around to installing it. Installation was super easy and it works great. Thanks Ray!!
08-22-2018, 06:32 AM
#239
08-22-2018, 06:44 AM
#240
How to order:
Payment is $45 via PAYPAL for One Door Claw, to searay230@gmail.com. Select "Friends and Family", and under "Comments" include your address for US Postal delivery. Please include your forum name, too.
PM me if any questions! Thanks, Ray
