01-22-2017, 11:30 AM
#2231
Originally Posted by Ben10281
pjpvi, I just sent a PM about your old compressor. Curious what your plans are for it.
Yep, I saw that and will reply.
A little in defense of the old compressor, when I pulled the airline apart from compressor to air tank, the fittings at both ends were corroded inside (obviously not all brass!) and the opening was extremely small. That may explain why the performance gradually degraded over the years.
Phil
- 2005 EB50 6.0PSD - SMB 4x4
01-22-2017, 11:47 AM
#2232
Ben, if you and Phil work out a deal, I can get it to your folks if you want to save on shipping.. Phil was potentially interested in checking out my CCV top anyway..
01-22-2017, 07:40 PM
#2233
Rally, thanks! If Phil decides to part with it I will let you know!
Sent from my SM-G935V using Tapatalk
01-27-2017, 11:04 AM
#2234
Swapped out the track bar ball joint. I wasn't having issues necessarily but it was on my list of stuff to do anyway so for 30$ and a Napa tool rental it's done.
I will say that the Napa ball joint tool kit I got was less than ideal. I can't remember the name but I think it's Napas brand.
The quickest way I found to remove them was to just cut the ball joint at the bottom of the ball and use the press directly on it with the receiver cup above it to press it out. The stock Ford ones are so long I couldn't fit the press over the ball joint to even press it out.
Getting the new one in took being creative but if you get the right kit it shouldn't be an issue.
01-28-2017, 10:23 PM
#2235
Fabbed a better mount for the sPod. There's not much room to add anything under the hood on a van with a 6.0. The mount is on a hinge so you can swing the source unit up to check the oil or change the fuel filters. The spring at the front holds the the unit firmly down when the hood is shut.
2011 VW TDI Golf for hwy fun
01-29-2017, 02:16 PM
#2236
Made sure the moto fit with the new Baja box extreme Fab made me.
01-29-2017, 06:03 PM
#2237
Hi Gooseberry.
That's just what I want.
Does it swing out? Can you post more pictures?
Cheers Doug
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
01-29-2017, 07:34 PM
#2238
Originally Posted by Sheriffdoug
Hi Gooseberry.
Cheers Doug
It does not swing out and not sure I would want it to off-road. I going to make a new handle for the jack so I push down on it and not push up under the spare tire.
This is what I have.
http://ultimatemxhauler.com/
01-30-2017, 10:14 AM
#2239
Why is that, lots of wiggling going on? I was looking into one of these but not sure how it would handle bumpy trails.
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
01-30-2017, 10:18 PM
#2240
I use this one off-road with a couple tie downs off each corner. I was saying a swingout with this might not be a good idea.
Sent from my iPad using Tapatalk
