06-11-2019, 08:11 PM
I always try to purchase my batteries from a source that I can get a warranty replacement from when I'm on the road, if I needed to. That typically points me toward the more common brands, or more common stores.
06-11-2019, 09:59 PM
The Carbon foam AGM is much like lithium, but with out the lithium cost. They do cost more than a traditional AGM. With a lifeline the number of expected cycles is 1000 with a 50%DOD, while the Firefly is 1000 cycles with a 80%DOD. You actually get 3600 cycles if you stayed at the traditional 50%DOD with the firefly. The other great thing it is perfectly OK to give it a partial charge. Standard AGM like to be charged back to full as soon as possible. This is probably the bigger killer than actual cycles in our usage.
06-11-2019, 10:44 PM
That's the way I read it - you can draw that carbon foam battery down to 20%. Incredible isn't it? Down side is the cost but I'll bet they last longer as well. Something to think about...
2002 E350 7.3 RB50 SMB
Quigley 4X4 Leaf Spring Conversion
06-12-2019, 08:13 AM
Originally Posted by Twoxentrix
These may be of interest - I was going to upgrade to two of these 100amp/hr Firefly Oasis carbon Foam batteries, unfortunately had to return them and go with a 210 Lifeline replacement - I would have needed to fabricate a new cradle for them within 1 day and simply didnt have the resources to accomplish this before leaving for Holiday.
I still plan to go this route since I'll have more capacity to draw from, but will actually try get 3 to fit.
https://oceanplanetenergy.com/advanc...asis-group-31/
Out of curiosity, I found the manual to the Oasis Group 31 battery. The manual doesn't provide much insight unfortunately.
06-12-2019, 10:20 AM
06-12-2019, 12:27 PM
Originally Posted by Cyrull
If you are willing to order a second one I will take one and pick it up from you at BCOR if you are willing to haul it up. The batteries are too heavy so my mail forwarding service in WA won't take them.
The Oasis carbon foam battery looks like an excellent option for our vans. I want to take a little time to look further into it. I don't think I have time to modify or fabricate a frame for these before BCOR so I may get the Apex 4D as a temporary solution. They have a one year warranty with free shipping.
Cyrull - I will PM you when I decide in the next day or so.
06-12-2019, 03:48 PM
Not sure if you all noticed, but the APEX batteries automatically generate a coupon code (ANDYCOST) when you add them to your car, which provides a 50% discount.
06-12-2019, 07:35 PM
If anyone is considering the Li Ion Carbon Foam batteries, they should read the thread titled "Carbon Foam AGM Batteries".
2006 EB 6.0 Diesel, custom gaucho,
Espar hydronic and heat, 2 Solara panels,
Trojan F&R, ARB lockers, Warn winch.
06-12-2019, 08:55 PM
Ok, nix the coupon. I ordered a battery and got an email from them a couple hours later saying it was a mistake and they won't honor it. Boo.
06-12-2019, 09:17 PM
#20
Boo. Hiss. Boo. Hiss.
I'd cancel the order based on GP alone.
Them bastiges
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
