Hi Scalf,
Thank you for your reply! All the wiring is factory. The solid red wire is the hot wire to the aux battery. Testing that lug shows the same volts as the aux battery.
I'll have to double check the other wires. One of them got voltage when the key was on, but the other never got voltage.
One other thing is when I was testing everything yesterday, I didn't have it bolted back down so that could have been my problem as well.
Thanks again for the info and I'll post back once I get some time to tackle it again.
Originally Posted by Scalf77
For the most part the solenoid d
oesn't care. But the wh/vt larger wire should always be hot, you can check with a volt meter. The red/yellow and red ( which is probably not factory) can go on the other side. It says you also have another smaller wht/vt going to the coil, this should be 12 volts when the van is running. The ground for the coil is the connection of the solenoid to the body of the van. So make sure that is a clean connection. You should be able to use case of solenoid as your ground connection. If your not reading 12 volts for either of the 12 volt connections it could be grounded poorly.
The red yellow should have 12 volts when running, if not work backwards.
