Old 04-19-2011, 10:49 PM   #11
Re: GFI won't reset despite power???
If the bus strip had heavy moisture on it, it's very possible for you to hear a electrical buzzing sound when power is supplied to the panel; I just had that happen a few weeks ago on a customers panel and it usually has to do with a dusty bus strip that gets wet. Usually it takes a lot of humidity or water to do it but what dhally posted is very possible also. I took it you were hearing the buzzing sound away from the GFI. I'd have SMB pull the breakers to make sure everything is clean and nothing tracked. Good luck.
Dave
Old 04-23-2011, 01:44 PM   #12
puahone's Avatar
SMB reported the electrical systems to all check out.
Problem seems to be gone with the very damp weather.
I'll let you know if it pops up again...
Robert
Robert
___________________
2010 Ford 6.0PSD EB-50/E-PH SMB 4X4
puahone is offline   Reply With Quote
PigPen
velo47
TumbleWeed
Sarah
