Old 01-01-2009, 02:40 PM   #1
surfgeek33's Avatar
Hella 500 Fog Lights wiring question
I'm installing my fog lamps on our Aluminess bumper. Is there a way to wire the lights without tapping in to my high beams? I ran the wires, ground, etc. in the correct connection on the relay, but did not splice into the high beams from the switch (I want the Fog Lamps to be independent), and no power. Do I need to get a new relay or wire differently? Unfortunately, the instructions only show how to wire the light with the high-beams. Sorry for being naive, but I am new to the world of 12 V and DIY stuff. Thanks guys!
"I do, cellularSTEVE" :o)
Old 01-01-2009, 04:21 PM   #2
Jeffrey's Avatar
I added three sets of lights to my Road Armour front bumper. I never connected to the headlights. All the circuit needs is a signal that 12v. is present, so I connected them all to a hot spot in or around the fusebox. I can use all those lights alone if I wish to.
Old 01-01-2009, 04:31 PM   #3
Ray, I wired my auxilliary lights into the parking light wire. So, as long as the parking light is on, the lights can be turned on. I made a post about how I did the wiring several months ago. Let me know if you need it.
Old 01-01-2009, 06:58 PM   #4
surfgeek33's Avatar
Jeffrey,
Thanks for the tips!
Geoff,
Thank you so much for the install guide. I ended up using your wiring our fog lights like how you did it on your write up. Thanks again!
I LOVE this Forum!
Old 01-02-2009, 09:31 AM   #5
Mine were wired directly to a 12 volt circuit until I left them on during daytime fog after shutting the engine off. I now have them on the ignition side so when the key is off the lights are off. I can turn the fog lights on when needed for things like setting up camp without having to run extra lights that deplete battery power.
Old 01-02-2009, 10:34 AM   #6
jlrray's Avatar
Send a message via ICQ to jlrray Send a message via AIM to jlrray Send a message via MSN to jlrray Send a message via Yahoo to jlrray
Where is that wiring Guide? Why do you want to use a relay when installing lights?
JOe
jlrray is offline   Reply With Quote
Old 01-02-2009, 11:24 AM   #7
Joe, if you do a google image search for HELLA wiring you should be able to find it. Using a relay prevents a high load from drawing straight off the switch. The 500's come with a relay to use with the Harness. It's the correct way to wire the lights.
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 01-02-2009, 11:59 AM   #8
surfgeek33's Avatar
JOe
Joe,
here is the link to the great install guide that sdwindansea wrote up. It is very helpful! Hope this is what you mean regarding "Where is the wiring guide?"
http://www.sportsmobileforum.com/vie...t=piaa+install
Old 01-02-2009, 12:40 PM   #9
jlrray's Avatar
Yes. Thanks.
