Old 07-08-2018, 09:01 AM   #1
House batteries not charging while driving
Got a new-to-me 1998 Chevy smb. It has 2 house batteries to run the fridge and other stuff. The batteries charge great when connected to shore power. However they don’t charge while driving. I located the battery isolator smb installed under the hood and only 2 of the 4 posts have anything connected. It appears the previous owner bypassed the isolator to connect the starting battery directly with the alternator, hence why the batteries don’t charge off the alternator.
My question is this: how do I actually test to figure out what is going on? I have a multimeter, but no idea how to use it or even which setting to set it on. Then I don’t know what to touch the little probes to or what I’m looking for when I do.
I’m concerned the isolator went bad so they previous owner bypassed it, but he could have bypassed it simply because he didn’t drive much and was constantly plugged into shore power.
Please help me learn!
Old 07-08-2018, 09:04 AM   #2
This is what my multimeter looks like.
Old 07-08-2018, 10:11 AM   #3
Bbasso's Avatar
Probably best to hire a 12v tech to get it right again.
And strongly consider a Bluesea 7622.
Rob.
Current:
And had three other E350s...
Old 07-08-2018, 11:11 AM   #4
try reading this and post back if you still need help. My suggestion is to ditch the isolator and go with a Blue Sea separator.
http://www.sportsmobileforum.com/for...ches-7991.html
Old 07-08-2018, 11:15 AM   #5
Grampswrx: I can help you out.....drive the rig over.....
I'd also consider the Blue Sea 7610 ACR if you are on a budget. About $80
Old 07-08-2018, 11:54 AM   #6
arctictraveller's Avatar
Getting to know your multimeter is very worthwhile. Here is a start
https://learn.sparkfun.com/tutorials...e-a-multimeter
Old 07-08-2018, 12:00 PM   #7
I was trying to avoid having to run new wiring by switching to the blue sea. But that’s probably the best thing to do.
Old 07-08-2018, 12:01 PM   #8
I may take you up on that! Heading to Baja on Wednesday, so I’ll probably take a cooler and make that work for the weekend. I’ll see if we can set something up when I get back! Thanks!
Old 07-08-2018, 12:13 PM   #9
Wow, isn't there a heat wave going on? I'd be interested to hear how your trip works out.
Old 07-08-2018, 12:31 PM   #10
Scalf77's Avatar
This thread has a procedure for testing an isolator (Post #7). also pictures in following post.
http://www.sportsmobileforum.com/for...ues-20410.html
