Originally Posted by dhally
I've done a little vomit in ng in the van. I found cables and cords to be a BIG annoyance. Once everything is hooked up, don't move or get up because it will rip all the cables out...
They make laptops for a reason!
No idea what vonit in ng means, but I totally agree on cables and cords.
So the idea here is thus...
Raspberry Pi 5 which is a system on a chip type computer, about the size of a deck of cards, a bit taller though...
The white cable is the power which is USB type C 27 watts max, and the black / gray cable is the micro HDMI to HDMI cable.
The computer box is no bigger than one of those hinged VESA wall mounts, and where I intend to mount, I have access to install 12V power ports for the high powered USB 3 and USB C power.
So the Pi would be mounted on the back of the monitor, monitor power and Pi power would be routed together along the VESA mount to the wall so never seen. HDMI cable would be run entirely to the monitor and hidden behind it. Going to switch to a 3ft cable instead of the 15footer that is there now.
My keyboard and mouse are Logitech Unifying MK550 and are wireless connecting to the Pi via that Logitech Unifying receiver dongle.
Should there be a reception problem with the USB simply pull the dongle, and install it to a USB A / USB B cable routed to just under the monitor, and again mount it don't just let it dangle. Gorilla tape would be great for this, it's black, so hides well, and bonds REALLY well...
So in the space the human occupies, there would be no cables anywhere in the way, unless of course I opted to not mount it, then it would be power cables from the Pi and monitor to the wall along the countertop during setup / takedown.
The concerns are screen real estate, and power consumption.
As a reminder, I have 600w solar, 40 amp DC to DC charging, and 400 amp hours LiFePo4 battery.
I could just as easily use my laptop. An Asus ROG Strix G17 G713 AMD Ryzen 9 5900HX, a couple of years old, but a top tier laptop for its heyday... 17" screen GeForce graphics, fast Ryzen processor, 16GB RAM, nice machine, but that 17" screen is very limiting. I know LOTS of folks make it work, I am wanting to be comfortable as I work, not just make do. Honestly I could accomplish the same thing with the laptop to an external monitor, but power consumption would shoot way up...
