Has anyone found a good way to disable dome lights on Econoline (2006)
Looking to find a super clean and concise way to disable all dome lights from a single point in my 2006 Econoline with the old style mechanical pull-out headlight switch.
From looking at the schematics, I believe the easiest way to do this would be to interrupt the black/white trace wire at the instrument cluster OR the black/light blue trace wire coming off the interior lamp relay.
Ideally I would also be able to bypass the battery saver relay so I can turn my dome lights on indefinitely as needed, I have LED bulbs so the draw is very minimal.
Turning the lights on from a switch is easy, just ground one of the door switches. If I used another relay and diode isolated it I could bypass the battery saver relay easy peasy
Thoughts?
