Old 12-21-2008, 10:09 PM   #1
deminimis's Avatar
Prosine Installer mode?
I need to change battery type but the panel keeps indicating I need to enter installer mode. How do I do that? Do I unplug the data cable from the panel into the sync port on the inverter unit? I have two ports on the panel, but makes no difference if I try the second port (which is how I thought you were supposed to do it). I'm confused. Thanks.
Old 12-23-2008, 08:12 AM   #2
AEJ
On the prosine 2.0, you enter the installer mode when the panel switch is set to configure and you press the "escape" button and Down arrow simultaneously. This should allow you to change the data .
Al Jaffa
2006 EB-50 Q4x4 V10
AEJ is offline   Reply With Quote
Old 12-23-2008, 08:45 AM   #3
deminimis's Avatar
Thank you thank you thank you!!
