Old 03-07-2012, 09:39 PM   #1
Dango's Avatar
Removing dash to install switches...help!
Can't find info anywhere. I want to install 2 switches in upper left of dash. I've tried but can't even figure out how to get the dash past the headlight switch. Sooo, before I go and break all kind of s---, thought I'd ask the pros. Can anyone help me w/this process?
'94 E250
Thanks-
Dan
Dango is offline   Reply With Quote
Old 03-07-2012, 11:41 PM   #2
Ultrasport12's Avatar
Re: Removing dash to install switches...help!
To remove the headlight knob there is a small notch on the back side of the knob. You need to use a small screw driver or a pick to depress the tab on the clip towards the rear of the van and at the same pull the knob off. After the knob is off the trim behind the knob just un-threads. As for the dash insert the clips can be stiff so be careful while pulling it off not to break anything.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 03-08-2012, 08:08 AM   #3
Dango's Avatar
...and then all of those screws or are their clips that I pull out?
Thanks.
Old 03-08-2012, 09:49 AM   #4
I am not sure on your year but mine has two screws on the top by the gauges and then about ten clips.
2004 F-350 Dana 60
Old 03-08-2012, 12:31 PM   #5
SheepShagger's Avatar
As Ultrasport12 said, just screws around the gauge (can't remember if there are any in the vents), then clips out. Typical Ford clips that will probably break the plastic on at least one lug when removed though.
I also remember having to tilt the steering wheel all the way down and put the gear lever in 1st to get the dam thing out. So make sure your keys are handy when you start pulling on it.
Old 03-08-2012, 01:48 PM   #6
Old 03-08-2012, 07:32 PM   #7
Dango's Avatar
Thanks all- mission accomplished. I have to admit, I probably wouldn't have figured out the headlight switch removal on my own. Furthermore, there were only two clips- one by each vent. I now have two switches installed (after all kinds of cutting of plastic and such) and one mega-loud, wake-your-arse-up horn.
Thanks again
Old 03-09-2012, 02:36 AM   #8
Gnarvan's Avatar
Do you have any pictures of the installed switches? I'm always looking for dash real estate to mount switches.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 03-09-2012, 08:20 AM   #9
Dango's Avatar
For my '94 it was an easy choice for location...big block of real estate for switches. Behind the dash, however, was a little more challenging.
Old 03-09-2012, 08:27 AM   #10
pjpvi's Avatar
I have to ask, what did you use for a horn? My family always laughs at how wimpy the horn is in the van.
Phil
Phil
- 2005 EB50 6.0PSD - SMB 4x4
