Old 11-11-2010, 05:21 PM   #11
Re: Replacement Stereo Power Woes
It's on when the van is off right? Just checking!
Maybe pull the stereo, jury wire a light (eg. small turn signal bulb) and run around a bit to see if you can isolate when the light goes out.
I'd also replace the fuse just because.
Old 11-11-2010, 06:47 PM   #12
spurious's Avatar
I may have missed something in the quick reading, but it sounds like you are testing the power wire that has power for a designated time. When you turn the key off the radio will have power for 5 min. And turns off when door opens or timed out?
spurious is offline   Reply With Quote
Old 11-11-2010, 07:38 PM   #13
Yes you don't want to be on that circuit!
Old 11-12-2010, 05:33 PM   #14
Testing with a bulb as we speak. I'll try a fuse depending on what happens.
2004 EB50 SMB 4x4 V10
falbhan is offline   Reply With Quote
Old 11-17-2010, 10:39 AM   #15
Well, I'm as puzzled as ever. Tried the bulb test and the bulb stayed on. As soon as I round up a fuse I'll pop that in and see what effect it has.
Old 11-17-2010, 11:10 PM   #16
spurious's Avatar
Well your situation is interesting.
Ok I'll ask some questions.
1. Your new stereo does it plug into the original wiring harness, if so are you using original connector?
2. If not what wire are you connecting to? (colors)
3. What are you grounding to when testing? (try grounding to chassis, then to the wiring harness ground)
By chance you might be losing your ground???
Old 11-18-2010, 09:13 AM   #17
How long? While driving? How long after shutting down the van and closing the doors?
OK, so alternate theory- could it be the ground wire for the radio?
Old 11-18-2010, 01:22 PM   #18
Current flow can cause those test probes to light up. You don't own a voltmeter? The light probes are great for finding a hot circuit but like whats posted, the ground wire (Aligator clip) must be hooked to the chassis somewhere not another circuit or wire unless you know it is a dedicated ground.
Old 11-18-2010, 03:15 PM   #19
Into the original harness I'm using the harness that SMB installed with the original VAIC N1. All my testing has been through the yellow wire which matches up to the red/white on the Ford connector. I suppose the "AVIC" harness could be a problem, but I hate to cut into the Ford wiring.
Grounding directly from stereo to the grounding point SMB used for the AVIC. A steel tube/bar that runs horizontally directly forward of where the installed stereo sits.
Old 11-18-2010, 03:20 PM   #20
Well over an hour with the vehicle parked. I've never had a problem as long as the keys were in and on ACC. Never tried with the ignition on.
Hard to imagine it's the ground. If it is it would have to be the contact between the connector and the steel tube it's screwed to as the ground wire and connector were tested directly to a battery and passed.
