Old 10-15-2009, 08:32 AM   #1
Shore Power Cable question
bought rig used
no cable
once i have the adaptor what SIZE and LENGHT do i need
also need a fairly long one for:
1) pluging in at home
2) pluging in the generator far away ( in YOUR campsite
guage wire?
lenght??
thanx in advance
Old 10-15-2009, 09:26 AM   #2
Re: Shore Power Cable question
Why not just make it easy on yourself and visit your local RV supply place and pick one up? They come ready made in several lengths. Make sure to pick up the adapter that will allow you to plug into 30 amp sockets as well as regular sockets.
CharlyBaltimore is offline   Reply With Quote
Old 10-15-2009, 09:57 AM   #3
As CharlyB said... Pre made cable is MUCH cheaper than make-it-yourself. (For some reason)
West Marine sells 50ft. 30 Amp cables (part# 9329897), for (sometimes), as little as $49.99; but usually $79.99. Bulk cable and end fittings are about three times that if you make up your own. Go figure. The adaptor from W.M. (part# 203901) is also $79.99.
Bill
NO2B
Old 10-15-2009, 10:01 AM   #4
is 30 amp enough, i see 50 ampers out there?
i agree w/ ready made
was considering an adaptor and using my existing Heap of extension cords
but a ready made is the deal
now:
30 amp vs 50 amp ??
length, does is matter??
and of course Color !!
Old 10-15-2009, 10:19 AM   #5
LenS's Avatar
Size of cable depends on how many amps you need to draw in your rig.
Our rig uses 15 amps max so a 12 gauge cord is ample for us. We take two 25 foot cables and that has always been enough to plug us in.....99% of the time one cable is enough.
Len & Joanne
The Green TARDIS
Old 10-15-2009, 01:35 PM   #6
I can't imagine you ever needing 50 amp. Plus the cord would put your rig over gross
Bill
NO2B
Old 10-15-2009, 01:39 PM   #7
The biggest load you have is the roof AC, and it only draws 8 amps at full load. A 15A circuit is all you need. 12Gauge wire.
Old 10-15-2009, 02:41 PM   #8
Are there any cheaper sources... RV Junkyard maybe? I'll be looking to pick up a second since I always hate putting the one in the bumper right before leaving home...
Old 10-15-2009, 03:39 PM   #9
The connector SMB installs is a 30A 125V connector. The mating connector is not cheap ~$35 at McMaster-Carr. Otherwise, I'd suggest you buy the connector and mate it to any old extension cord.
Old 10-15-2009, 05:23 PM   #10
My RV Interior / Systems / Builder Guru picked up an adaptor and cord at Loews
will ck stats
thanx for all the input
bw
ps
i think i might need 100 feet to get my generator in YOUR campsite
