Old 12-12-2015, 12:12 PM   #1
Understanding the Blue Sea 7620 or 7622
Hopefully this helps people understand the Blue Sea 762X magnetic latch relay.
Old 12-12-2015, 03:49 PM   #2
depark's Avatar
I just watched the video, Great Job Greg! It's nice to see it in action and should clear up any mystery of how it operates. I know that you are particular about things so I would like to point out 1 slight error in the video. At 10:15 you are describing how to wire the 2146 switch to power. In the video you state "Connect a 2 amp fuse wire to switch terminal 8 & terminal 1". The fuse wire actually connects to terminal 8 & terminal 3 via a jumper wire. Your diagram is correct, the voice and text are off.
Just thought you and everyone else should know.
Cheers
Darryl
2006 Ford E250 RB 5.4L gas
Clydesdale 4WD Conversion
VA7DTP
Old 12-12-2015, 06:01 PM   #3
Thanks for the feedback, fixed
Old 12-12-2015, 06:53 PM   #4
Bbasso's Avatar
I've been putting off installing the 7622 because I am unsure how to use it properly. You just gave me the knowledge and inspiration to get it done.
Thank you.
Rob.
Current:
And had three other E350s...
Old 12-13-2015, 05:21 AM   #5
Excellent video!
Presentations like this specific to a component or part are so much more helpful that just reading installation/operation instructions. Being one who has to see something in action to fully understand it this was great!
Old 12-15-2015, 07:54 PM   #6
Gatorbait's Avatar
It's so simple it's confusing lol. I wish I had this a week ago before I put it together. good job on the video.
Gatorbait is offline   Reply With Quote
Old 01-13-2016, 02:47 PM   #7
In your wiring diagram, and in the wiring diagram in the Blue Sea instructions, it looks like there should be fuses on the lines from the batteries to the 7620/2 stud terminals A &B. Though in the Blue Sea instructions it says that if it is to be used for cross connect, fuses between terminals A and B and each battery are not required. I am using the 2146 switch to provide manual cross connect (I) and Isolate (O) function. So I am assuming I don't need fuses (circuit protection) on these lines. Is that right? I am replacing a Sure Power 1315 which SMB installed originally and they had no fuses on those lines. Of course, it did overheat and burn up so I want to make sure I do it right. Thanks.
eruddick is offline   Reply With Quote
Old 05-06-2017, 09:58 AM   #8
Bellpilot's Avatar
I just realized my Blue Sea is not connected to the ignition switch. When I have it set to auto it seems to work fine. Any issues not having this not hooked up to the ignition?
2010 E350 6.0 4x4 EB 50 SMB
Old 05-06-2017, 02:34 PM   #9
Not hooking up the start isolate out feature is not required, it could be a benefit if you had sensitive electronics, and don't want them connected during cranking.
Old 05-06-2017, 02:53 PM   #10
Bellpilot's Avatar
Thanks Greg!
