Originally Posted by Steve C
Not sure what fixtures you're referencing. Post pictures please...
Also, lots of information on this topic has been posted previously on this forum.
Yeah, it would help if I knew what to search for to find the topic info...
Not sure why the forum software rotated my image on upload, it is correct on my phone and in Google drive...
I am unaware of any different ceiling / wall llights aside from the lamps whcih are a bit more obvious.
I THINK but am not certain that the lens cover is held on by the ends, / screws in the end pieces where the switches are, but I wanted to be certain before i go fishing this apart.
My thought process here is replace the heat generating energy sucking bulbs to retirement and replace them with some tiny juice sipping LEDs, at the reaar between the back doors tap into the circuit for a dual USB power port that will power LED light strips that will run the length of the interior on either side of the opening for the penthouse. Reduce overall electrical use, increase lighting options, win win.
