SMB OEM fuse panel question.
So my 93 SMB has a 6 fuse fuse box. This is in turn mounted to a piece of plywood that is L bracketed into the front face of my drivers side dinette base. The circuits are wired, and a hole was drilled by SMB apparently when they ran the wires to route them behind.
I am wanting to add 12V circuits, most notably for the fridge (done) and for my added 12v charging / USB charging ports, and for the water pump and gasoline heater. I have the open fuse spaces, but am concerned about drilling through like SMB did for fear of hitting the original wiring.
Is there any good reason I shouldn't simply route the wires around the side of it and just go around instead of through? I already did it with the fridge and it works great.
I figure once I get the wiring done, I will print out a fuse panel label, and create another addendum to the OEM manual I have to show the changes I have made.
