Old 02-15-2011, 06:29 PM   #1
Zeta's Avatar
Extreme Aire System
OK. I give up. How is it supposed to work? Does it keep the tank full all the time, or do I have to turn it on somehow?
TIA
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 02-15-2011, 08:23 PM   #2
Roonie's Avatar
Re: Extreme Aire System
There is a switch. Mine is located next to the front fog light switch and 4x4 light. Once tank is full it shuts off. If it isn't turning on then there is a reset switch on the frame rail under the cargo doors. Flip the red switch in to reset it.
Old 02-15-2011, 09:24 PM   #3
Zeta's Avatar
The only other switch I have ups the idle. Is that it do you suppose?
Z
'06 RB50 SMB Diesel
Old 02-15-2011, 09:51 PM   #4
Roonie's Avatar
Are you sure you even have it? Mine is located behind the atlas II transfer case.
It needs a switch to turn it on. It is not automatic.
Old 02-15-2011, 10:57 PM   #5
Zeta's Avatar
I'm sure.
Z
'06 RB50 SMB Diesel
Old 02-16-2011, 02:24 PM   #6
Greg In Austin's Avatar
Mine uses a switch. AND the van has to be on.
I suppose it could be wired to just be on when the van is on....BUT I think you would know it. When I turn it on, even with the PSD6.0 I know it is on.
Sounds like a call to SMB to find the switch.
Greg in Austin
Old 02-16-2011, 02:29 PM   #7
Jeffrey's Avatar
SMB did not label my switch, next to a few other identical switches. If none work, check the breaker for the compressor, located in front of the house battery boxes. Mine has tripped a few times for no apparent reason.
Old 02-16-2011, 02:49 PM   #8
Jeff's thought made me think of something else....
If you have a switch that could be it, but that does not trigger the compressor, there is an in line fuseable-link-kind-of-thing that shorted out and burned up once on mine. It kept the circuit from being completed and thus switch ON got me nothing.
Greg in Austin
Old 02-16-2011, 02:58 PM   #9
Zeta's Avatar
Fixed. Some incompetent had disconnected the switch when installing an engine monitor.
BTW. Did I show you guys the Edge Insight I installed myself?
Z
'06 RB50 SMB Diesel
Old 02-17-2011, 06:42 PM   #10
Z
I hate that when that happens...you're supposed to say the dog, cat, or your wife did it. If you don't have any of those you say Bush did it.
Queen bee
Deaner
(No name yet)
Orv
