Old 10-18-2020, 08:57 AM   #21
I finally found this. When catching up on this post recently I knew I had seen a better option, probably on Expedition Portal. Here 'tis. Still a couple hundred less than a Fiamma, quick deploy, no poles necessary but they are there is you want them for long term/bad weather use. This is the best all around awning I've seen in a long time. Not cheap but looks to be worth it and big enough for full size van coverage to side doors.
23Zero Peregrine awning, $999.
https://expeditionportal.com/forum/t...ilable.208254/
https://23zero.com/product-category/awnings/
Old 04-22-2021, 03:25 PM   #22
Skivvie's Avatar
Did you ever get the brackets sorted MorieSugg?
Skivvie is offline   Reply With Quote
