Old 10-30-2007, 07:26 PM   #1
Outdoor Shower Mats?
I'm trying to figure out a good solution for a "mat" of sorts that can be used to stand on when using the exterior shower. We need it to be comfortable to stand on, while at the same time raising us off the ground a bit and adequate drainage. Obviously, it must be easy to store and clean as it would be used on pavement, dirt and sand.
One solution I'm thinking about is a marine deck mat, somethin like the "Dri-Dek" which could work well. Dri-deck.com.
Does anyone have any other solutions or suggestions? Thanks for the advice.
Old 10-30-2007, 07:37 PM   #2
After reading this I went out and stood on my Lynx Blocks barefoot... bad news I'm afraid, unless you've got feet of iron!
I tried 'em upside down too, just for the record.
Old 10-30-2007, 10:39 PM   #3
Shower mat
jage
I use a 20x30 inch teakwood mat .. It's a bunch of 1 inch strips spaced about
a .250 inch apart screwed together with spacers.. It's 1 inch high... I've had
it for 20 years... You can put on top of rocks. I'ts strong.
JM
2006 Sportsmobile PSD-----69 Jeepster----BMW1200GS---450 KTM----450YFZ--- 2007 F150----2005 Nissan
myriadmyriad is offline   Reply With Quote
Old 10-31-2007, 04:20 AM   #4
J.C. Penny online has a 16"x21" teakwood shower mat as you describe for $50. Googled teakwood shower mat.
1995 Dodge 3500 5.9L V8 2wd EB-21 PH
mikestead is offline   Reply With Quote
Old 10-31-2007, 07:47 AM   #5
alta825's Avatar
I got a pretty slick little folding shower mat at the local Sportsman's Warehouse. It is a folding cedar shower platform that uses 1" wide slats that is about 1'x1.5' when it is folded up and stows perfectly in the small compartment in the back where the hot water is.
Nice thing about cedar is that it is also mildew resistant
Cheers,
D
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 10-31-2007, 10:56 AM   #6
Cheers,
D
Is this it Alta? GSI Cedar Shower Deck
This could also be something I could easily make. However, teak is a longer lasting material, although more expensive as well. The nice thing about those dri-deck mats I mentioned is that you can throw them anywhere and not worry about scratching the interior of the van. They may be too low to the ground though.
Old 10-31-2007, 11:06 AM   #7
alta825's Avatar
that's the one - nice find.
Really have only used once since I got it, but so sfar so good and its nice and compact
d
Old 10-31-2007, 01:18 PM   #8
Jeffrey's Avatar
I'll be using a flexible rubber mat that I can roll up and stuff somewhere small. Large wooden platforms sound nice but are a storage issue.
Old 11-01-2007, 12:51 PM   #9
truckee55's Avatar
I use a mat that I got at the local hardware store. It's plastic, with a raised rim and a 'diamond plate' texture. About 1.5' x3,' works perfect, and fits in the rear XL storage area. I have no idea what it's intended use was, but it's really just like a knock-off husky liner. The best part it was only $10.
Before I found it I was using a rubbermaid tub; drilled a hole in the side about 1" off the ground so it would drain.
Would send a pic, but the SMB is at Ford today Another story...
G. Wood
Truckee, Lake Tahoe, CA
'06 E350 Diesel, Quigley 4x4, RB-50
truckee55 is offline   Reply With Quote
Old 11-01-2007, 02:59 PM   #10
calclimber's Avatar
We just leave our flip flops on. No mat needed.
Quality doesn't come in a twist off
Craig
05 EB 50 V10 4x4 Baja Tan
calclimber is offline   Reply With Quote
